How to set use custom property values from this sheet on all sheets as uncheck in solidworks? See below the pictures. I uncheck then save the template, but after I create a new drawing, It still be checked and I need uncheck this manually everytime... Thanks in advance.
Once you make the change, save both sheet format and drawing template. Report back in case it doesn't work.
