working with appearances - questions
Question asked by Damir Galic on May 29, 2018
Latest reply on Jun 4, 2018 by Damir Galic
hello, I have a few questions:
1. is it possible to set scale for all new applied appearances to be 1?
2. how can I quickly copy/paste appearance with the same scale but automatic "mode" selection (cylinder/box) with 1 button press?
3. is it possible to select multiple items and apply appearance as mentioned above?
4. assuming you've got large object, should the appearance scale be the same for all objects?
5. Using SW brushed surface from imported object rather applies "specular" instead of "bump". Using specular you can at one point see the repeating texture pattern on the surface. What is the best way to avoid this is you want finer brush (such as scoth brite)?
