6 Replies Latest reply on Feb 24, 2019 9:38 AM by Jacob Corder
    How to get rotation angle from Transform matrix when exceeding 180 degree?
    Chiao Yang Chang
      I use a part to rotate 200 degree in clockwise direction about Z axis.(see Fig2)
      Use the following code to get orientation.
      However,when the angle exceeds -180 degree, the angle I get is 160 degree rather than -200 degree.
      It seems that solidworks changes direction automatically to calculate orientation when exceeding -180 degree or 180 degree.
      How could I do if I want to get -200 degree information from the transform matrix?
      Dim swMathUtil As SldWorks.MathUtility
      Dim swTransform As SldWorks.MathTransform
      Dim orientxform As SldWorks.MathTransform
      Dim newtransform As SldWorks.MathTransform
      Dim vxform As Variant
          Set swModel = swApp.ActiveDoc
          Set swDraw = swModel
          Set swMathUtil = swApp.GetMathUtility
          Set swComp = swSelMgr.GetSelectedObjectsComponent(1)
          Set swTransform = swComp.Transform2
          Dim arr(9) As Double
          For a = 0 To 8
          arr(a) = swTransform.ArrayData(a)
          Next a
          Debug.Print "【Rotation Matrix】:"
          Debug.Print Math.Round(arr(0), 3) & "," & Math.Round(arr(1), 3) & "," & Math.Round(arr(2), 3)
          Debug.Print Math.Round(arr(3), 3) & "," & Math.Round(arr(4), 3) & "," & Math.Round(arr(5), 3)
          Debug.Print Math.Round(arr(6), 3) & "," & Math.Round(arr(7), 3) & "," & Math.Round(arr(8), 3)
          Dim R2D As Double
          R2D = 180 / 3.1415926
         Yrad = (-1) * arctan2(-arr(6), Math.Sqr(arr(0) * arr(0) + arr(3) * arr(3)))
         Ydeg = Yrad * R2D
         If Ydeg > 89.000001 And Ydeg < 90.0001 Then
         Zdeg = 0
         Xrad = (-1) * arctan2(arr(1), arr(4))
         Xdeg = Xrad * R2D
         ElseIf Ydeg < -89.000001 And Ydeg > -90.0001 Then
         Zdeg = 0
         Xrad = (-1) * -arctan2(arr(1), arr(4))
         Xdeg = Xrad * R2D
         Else
         Zrad = (-1) * arctan2(arr(3) / Math.Cos(Yrad), arr(0) / Cos(Yrad))
         Xrad = (-1) * arctan2(arr(7) / Cos(Yrad), arr(8) / Cos(Yrad))
         Zdeg = Zrad * R2D
         Xdeg = Xrad * R2D
            Debug.Print "【X-Y-Z fixed Angle】:"
            Debug.Print "A=" & Math.Round(Xdeg, 3) & " deg"
            Debug.Print "B=" & Math.Round(Ydeg, 3) & " deg"
            Debug.Print "C=" & Math.Round(Zdeg, 3) & " deg"
      Public Function arctan2(ByVal y As Double, ByVal x As Double) As Double
      Dim PI As Double
      PI = 4 * Atn(1)
      'Debug.Print pi
      If x > 0 Then
          arctan2 = Atn(y / x)
      ElseIf x = 0 Then
          If y > 0 Then
          arctan2 = PI / 2
          ElseIf y < 0 Then
          arctan2 = -PI / 2
          ElseIf y = 0 Then
          'undefined
      ElseIf x < 0 Then
          If y >= 0 Then
          arctan2 = Atn(y / x) + PI
          ElseIf y < 0 Then
          arctan2 = Atn(y / x) - PI
      End Function
      Public Function Arccos(x) As Double
      If Round(x, 8) = 1# Then Arccos = 0#: Exit Function
      If Round(x, 8) = -1# Then Arccos = PI: Exit Function
      Arccos = Atn(-x / Sqr(-x * x + 1)) + 2 * Atn(1)
      End Function
      Public Function Arcsin(x As Double) As Double
      If (Sqr(1 - x * x) <= 0.000000000001) And (Sqr(1 - x * x) >= -0.000000000001) Then
      Arcsin = PI / 2
      Else
      Arcsin = Atn(x / Sqr(-x * x + 1))
      End Function
      [Fig1]
      [Fig2]
