I'm still very new to SolidWorks and need some assistance on how to create a part. I need to create a cylinder that has one end closed (capped). I am able to create a cylinder by drawing two circles of the correct radius and then doing an extrude to the correct length. However, this makes a completely hollow cylinder and doesn't leave one end of it solid. I'd need to leave one end about 2mm thick (solid). How do I do this when doing an extrude?
The next part is I need to create 2 slits in the cylinder about .5mm wide from the open end down about 10mm.
Here is a picture of what I'm trying to achieve (only this one is slightly larger than what I want to design).
https://www.thingiverse.com/thing:1675311
Any help and examples would be greatly appreciated!
Kind Regards,
Nelson
I would extrude the hollow section like you have done and then close in one end using another extrude. There are a lot of ways to model a part like this, you could start by extruding a solid and extrude cut the section out that you want as well.
