For those of you experienced in modeling these types of sheet metal parts, what techniques would you use? From the attachment, it started as a SM part, but then I needed to add sweeps & lofts to close gaps as a flange feature cannot be modeled on a curved surface.
To create the bottom pads, I created a separate solid body and used a indent feature (similar to forming tool). Could this entire model be created from one or more forming tools?
In Pro-E (Pro/Engineer), advanced wall features are available (revolve & blend), which can be flattened. I started this part in SW 2007, but I may be permitted to finish in SW 2009. Does SW 2009 have any additional sheet metal capabilities not present in SW 2007?
I typically do more plastic injection-molded part design than sheet metal, which is why I used a hybrid modeling technique to achieve the desired results.
WT
