Compile error: Type mismatch
Question asked by Roni Ampuja on May 24, 2018
Latest reply on May 31, 2018 by Roni Ampuja
Option Explicit
    Dim swApp               As SldWorks.SldWorks
    Dim swModel             As SldWorks.ModelDoc2
    Dim swModelDocExt       As SldWorks.ModelDocExtension
    Dim swExportData        As SldWorks.ExportPdfData
    Dim boolstatus          As Boolean
    Dim filename            As String
    Dim lErrors             As Long
    Dim lWarnings           As Long
    Dim amountSaved         As Object
    Set swModel = swApp.ActiveDoc
    Set amountSaved = 0
    If swModel Is Nothing Then
        MsgBox "Ei Olemassa Olevaa Tiedostoa", vbCritical
        End
    If swModel.GetType <> swDocDRAWING Then
        MsgBox "Tämä Macro Toimii Vain Työkuva Näkymässä", vbCritical
        End
    Set swModelDocExt = swModel.Extension
    Set swExportData = swApp.GetExportFileData(swExportPdfData)
    filename = swModel.GetPathName
    If filename = "" Then
        MsgBox "Tallenna Tiedosto ensin ja kokeile uudestaan", vbCritical
        End
    'Save drawing
    boolstatus = swExportData.SetSheets(swExportData_ExportAllSheets, 1)
    boolstatus = swModelDocExt.SaveAs(filename, 0, 0, swExportData, lErrors, lWarnings)
    If boolstatus Then
        amountSaved += 1
    Else
        MsgBox "Työkuvan Tallennus Epäonnistunut, Error code:" & lErrors
    'Save as PDF
    filename = Strings.Left(filename, Len(filename) - 6) & "PDF"
    If boolstatus Then
        amountSaved += 1
    Else
        MsgBox "PDF Tallennus Epäonnistunut, Error code:" & lErrors
    'Save as DXF
    filename = Strings.Left(filename, Len(filename) - 3) & "DXF"
    If boolstatus Then
        amountSaved += 1
    Else
        MsgBox "DXF Tallennus Epäonnistunut, Error code:" & lErrors
    MsgBox amountSaved & " tiedoston tallennus onnistui"
On the line: Set amountSaved = 0      I get Compile error: Type mismatch.
Im trying to make macro that saves drawing and dxf and pdf. And then informs if saving of all those was succesfull but I can't get over this error.
