2 Replies Latest reply on May 27, 2018 5:13 PM by Nilesh Patel
    How to modify insert BOM macro?
    Kaijiun Cheang
      I am trying to insert a fresh BOM table to my drawing with macro.
      I am using the code below. But when i run it, it places the table to bottom left and also showing all the configuration i have on that assembly.
      How should i modify it so that it will be positioned based on the anchorpoint set on the sheetformat, and also only listed the current configuration of the drawing view?
      Thanks for your time and help.
      Option Explicit
      Dim swFeatMgr As SldWorks.FeatureManager
      Dim swView As SldWorks.View
      Dim swBomAnn As BomTableAnnotation
      Dim swBomFeat As SldWorks.BomFeature
      Dim anchorType As Long
      Dim bomType As Long
      Dim configuration As String
      Dim tableTemplate As String
      Dim Names As Variant
      Dim visible As Variant
      Set swModel = swApp.ActiveDoc
      Set swFeatMgr = swModel.FeatureManager
      Set swDraw = swModel
      Set swSheet = swDraw.GetCurrentSheet
      'Select View
      swModel.ClearSelection2 True
      Set swView = swDraw.GetCurrentSheet.GetViews()(0)
      'Insert BOM Table
      anchorType = SwConst.swBOMConfigurationAnchorType_e.swBOMConfigurationAnchor_BottomRight
      bomType = SwConst.swBomType_e.swBomType_TopLevelOnly
      configuration = "CLOSED-STD BIFOLD"
      tableTemplate = "P:\Data\Engineering\SOLIDWORKS\TEMPLATE\AM BOM TABLE.sldbomtbt" '"C:\KMI-Vault\Admin Files\SW - Templates\TABLES\kTable.sldbomtbt"
      Set swBomAnn = swView.InsertBomTable2(False, 0, 0, anchorType, bomType, configuration, tableTemplate)
      Set swBomFeat = swBomAnn.BomFeature
      Names = swBomFeat.GetConfigurations(False, visible)
      visible(0) = True
      boolStatus = swBomFeat.SetConfigurations(True, visible, Names)
      swFeatMgr.UpdateFeatureTree
