Hi everyone,
I've been trying to thicken this fan blade by 0.2 mm , but each time I get "thicken surface has failed". The blade does have a lot of sides due to its organic shape so I'm wondering if that's what causes the error. I've tried using stitch surfaces but that doesn't seem to work either. Is there something I'm missing?
Your Part has one Solid Body and no Surface Bodies.
Thicken works upon a Surface to make it a Solid. What you have is already a solid.
Perhaps you can select the faces on one side and see if that works. However, due to the intensity of imported polygons, you are talking about many many faces to select. I would not even attempt that personally unless someone has a way to select, for example, all visible faces from one side.
Other options include Offset Surface followed by Loft or Boundary or Filled Surface, then re-knit to a solid, but the same difficulty of selecting the faces would clearly apply.
