Hi All
I want to ask about SOLIDWORKS Plastic --> Runner Balancing
Is feature is active if the cavity conditions familly mold?
I'm having some work to be analyzed with SOLIDWORKS Plastic but Runner balancing is not active ?
from the picture I part that I do is multi cavity.
The runner balancing is supported only in multi-cavity. As the image indicates in the 2nd pic you have done channel design so the runner balance. In the 1st pic, it doesn't have any channel design so there is no runner balance.
Hope this helps.
Regards,
Micheal Johnson S
