Cuts vs holes in sheet metal
Question asked by Scott Leacox on May 23, 2018
Latest reply on May 24, 2018 by Scott Leacox
From another thread, it was mentioned that cuts and holes do not respond the same way in sheet metal.
I use cuts all the time in models so that many cuts can be edited at one time from the sketch perspective.
What advantage does a hole have over a cut? In specific when it comes to downstream operations like bolt patterns, flat pattern drafting, etc.
It will take me about 5 years to get the sheet metal documented at this company, then I will start doing assemblies. So I will not see some of the downstream effects for many years.
I just spent 4.5 years i solid works, and was about half done with the sheet metal there. Most of the time is spent because the target moves with many custom products and 100 "standard" products.
