I use the following code to get center coordinate of circle01 (C01) and circle02 (C02).
But the values are reference with part origin (see Fig1) rather than assembly origin (see Fig2).
There are two questions:
1. In the Measure Interface (see Fig3), there are no properties to get the center coordinate of cirle by selecting circle.
But I can use Measure to get center coordinate with reference to assembly origin manually (see Fig2).
How to use API like manual method in Fig2 ?
2. How to modify the following code to change the coordinate values with reference to assembly origin ?
e.g. change C01(-130,130,330) in Fig1 to C01(-130,116,-208.5) in Fig2
【Code using VB.NET】
Private Sub btnGetCenterPt_Click(sender As Object, e As EventArgs) Handles btnGetCenterPt.Click
swModel = swApp.ActiveDoc
swDocExt = swModel.Extension
swSelMgr = swModel.SelectionManager
Dim swMeasure As IMeasure
Dim swSel01, swSel02 As Object
Dim swCurve01, swCurve02 As Curve
swCurve01 = swSel01.GetCurve
swCurve02 = swSel02.GetCurve
Dim C01(6), C02(6) As Double
Dim i As Long
For i = 0 To 6
C01(i) = swCurve01.CircleParams(i)
C02(i) = swCurve02.CircleParams(i)
Next
MsgBox("C01 X= " & C01(0) * 1000 & ", C01 Y= " & C01(1) * 1000 & Chr(13) & "C02 X= " & C02(0) * 1000 & ", C02 Y= " & C02(1) * 1000)
Fig1
Fig2
Fig3
You need to multiple the position with component's transform: 2012 SOLIDWORKS API Help - Transform2 Property (IComponent2)
