Hi All,
I've used Solidworks in school but now that I have to for work, I'm trying to improve my skills and do things more efficiently. While sketching a hole, I tried to add relations to make it in the centre of a rectangular passage but could not seem to do it.
I know that I could very easily draw a construction line and fix the centre of the circle to that line, but is there no way no use relations to place it in the mid point of the rectangle? Thanks for all your help!
You can make use of relation to place the circle in the center of the rectangle, select the midpoint of the rectangle edge and give parallel relation to a center of a circle.
Hope this helps.
Regards,
Micheal Johnson S
