Is it possible in a design table to swap the rows and columns?
Can I have all the variables listed in the same column and configurations listed in the same row?
I'm thinking this is a simple yes or no question, but after some searching I haven't found an answer.
Thanks in advance,
Richard in Houston
No.
Breaks configs if you modify the table after it's created.
Locks you into the config you're in when you edit the DT.
Stick with the standard layout.
Cheers,
Kevin
