I checked out if you can download these from the SOLIDWORKS customer portal and it doesn't seem that you can, I will inform SOLIDWORKS as I would expect to be able to download from there.
I meant to say that the eDrawings website as far as I could see doesn't allow download of previous versions either, that's why I included the link to eDrawings so you could see.
Hi Marlon,
eDrawings
You will need to request an older version download by filling out and submitting a service request to SOLIDWORKS Technical Support:
Free Product Support Request | SOLIDWORKS
See SOLIDWORKS knowledge base solution S-068152 for more info:
Q - How can free eDrawings® users download old versions of eDrawings® that supports SOLIDWORKS documents, eDrawings® files, DXF, and DWG?
A - In order for free eDrawings® users to be able to download old versions of eDrawings® that supports SOLIDWORKS documents, eDrawings® files, DXF, and DWG, they need to create a service request with SOLIDWORKS Technical Support , by going to: https://www.solidworks.com/sw/support/fpsupport/fpsupport_req.htm?product=eDrawings%20Viewer
Make sure to accept this post as the solution if it helps so that others can benefit.
Lewis
