How to (not) break a sketch by changing "view as radius/diameter"
Question asked by Asko Kauppi on May 19, 2018
Latest reply on May 20, 2018 by Solid Air
Steps:
- open Halo.SLDPRT > Boss Extrude1 > Sketch1
Would like to show the slot's outer diameter ("outer pitch diameter + 2.5*module") also as a diameter, like the other dimensions.
Changing the viewing of a dimension should not change the sketch itself, right?
- right click on that dimension, > Display Options > Display as diameter
- save
If you click Stop and Repair:
What's going on here?
Expected:
- changing the way a dimension is visually shown should not break the sketch, or even change it in any way
Actual:
- changing breaks the sketch, and only the viewing by radius is a healthy option (note: press Ctrl-Q after reverting back to clear errors)
SW 2018 SP 2.0
