I'd like to tie the shaft to the slot (see picture), but the "slot mate" doesn't recognize the slot any more, since teeth have been added to it.
Expected:
- I would be able to select the slot, by clicking on either: the outside edge (no changes there), the corners (no changes there), and the slot mate would be established.
Actual:
- Slot mate does not detect any selections on the edited slot as a slot. Therefore, the mate cannot be made.
How would you do such a mate?
The teeth are added as a curve pattern.
SW 2018 SP 2.0
Asko,,, In your Halo part I made an offset surface of 0 all around your slot. This feature is right after your Boss-Extrude1 prior to you adding the teeth.
Then in the assembly I was able to use the slot mate on that. The screenshot is with the Halo body hidden.
Of course you can then hide the surface offset and unhide the Halo body.. This seems to work out pretty well since with the free constraint the shaft is still constrained to the ends of the slot.
