I created a crop view, but once the view is created some items are outside the border for the drawing view and I can't connect Balloons to them.
Also, it cuts off anything outside of that border when saved to PDF.
Coincidentally enough, a colleague asked me about this earlier today.
He had an exploded part (not cropped) that was getting clipped by the view.
Initially, it was far enough out that the clipping was a "band" across the part.
He moved in it (less explode) and the clipping was only one the end.
The resolution was to less explode it far enough inboard of the clipping edge.
It doesn't look like you have the explode room to do this.
Submit it to your VAR and see what they say.
Due to the client, I can't share data other than the story.
Perhaps other forum members with greater wisdom will chine in on this.
Cheers,
Kevin
Edit the crop, move the line outside the parts.
