I believe this topic has been discussed before but I couldn't find it
What are pro/con to have both on the same or different servers?
Hi Jake,
The database server typically is paired with the SQL Server installation.
SQL likes fast CPU and memory. Therefore, if feasible, it should be hosted on a server with suitable specs.
The archive server is always moving files across the network (LAN or WAN).
This server benefits from robust I/O and storage (due to the physical file versions being stored here).
Regards,
Joy
Joy Garon wrote:
Hi Jake,
Regards,
Joy
Thank you, Joy
Hi Jake,
Regards,
Joy
