The company I am at had the other cad user build a PC for visualize so that we both can use it for rendering, The problem is we both have visualize standard.
( no network rendering in Vis standard)
I think the only way for both of us to use this network Visualize machine is to install one of our license on it without solidworks( is used on main pc) and we both remote in?
If anyone has suggestions for a better solution I would appreciate hearing them.
Thanks in advance
Hi Francisco,
are you using locked licenses or floating licenses?
if they are floating then you can install Visualize on as many machines as necessary and just grab the license when needed.
