I'm having issues with a split line in a sheet metal part. I've attached a sample part for reference.
I make a part using base flange and add a couple Miter Flanges, I then add a split line box to one of the faces. When I make a drawing and select the flat pattern the split line disappears. When I go back into the model in the flat pattern configuration the split line doesn't show.
Is there a way to have the split lines show when using flat pattern? I know I can use the unfold command and the split line stays but not when I use the flatten.
Here is the finished part:
Here is the flat pattern:
Here is the unfolded one:
Peter,,, Uncheck "Merge faces"
Edit:.. Another screenshot.. Soul also have Simplify bends and Corner treatment unchecked for a correct notch.
