Transform Coordinate System In Macro
Question asked by Darius Teichroew on May 17, 2018
Latest reply on May 18, 2018 by Darius Teichroew
Hi, I have the following macro that exports the points of a sketch to a text file. That works fine. However, it's based on the default coordinate system, which is randomly different in each drawing. So I'd like instead to have it use the first exported point as the origin. I'm sure it's a pretty quick change, can someone show me what needs to change in my code? Thanks.
    Dim swApp                           As SldWorks.SldWorks
    Dim swModel                         As SldWorks.ModelDoc2
    Dim swSelMgr                        As SldWorks.SelectionMgr
    Dim swFeat                          As SldWorks.feature
    Dim swSketch                        As SldWorks.sketch
    Dim i                               As Long
    Dim bRet                            As Boolean
    Dim vSketchSeg                      As Variant
    Dim swSketchSeg                     As SldWorks.SketchPoint
    Dim nLength                         As Double
    Dim xValue() As Double
    Dim yValue() As Double
    Dim zValue() As Double
    Dim point_count As Integer
On Error GoTo error:
    Set swModel = swApp.ActiveDoc
If swModel Is Nothing Then Exit Sub
    Set swFeat = swSelMgr.GetSelectedObject5(1)
If swFeat Is Nothing Then
    Set swSketch = swModel.GetActiveSketch2
    If swSketch Is Nothing Then
        MsgBox ("you must select the sketch from feature manager tree or at least be in a sketch")
        Exit Sub
Else
    Set swSketch = swFeat.GetSpecificFeature2
        vSketchSeg = swSketch.GetSketchPoints2
        point_count = UBound(vSketchSeg)
ReDim xValue(point_count)
ReDim yValue(point_count)
    For i = 0 To point_count
        Set swSketchSeg = vSketchSeg(i)
        xValue(i) = swSketchSeg.x * 1000 / 25.4
        yValue(i) = swSketchSeg.y * 1000 / 25.4
    Next i
tFilename = swModel.GetPathName
sFilename = Left(tFilename, Len(tFilename) - 7)
Set fs = CreateObject("Scripting.FileSystemObject")
Set f = fs.CreateTextFile(sFilename & ".txt", True)
            f.writeline Format(xValue(i)) & "," & _
            Format(yValue(i))
   Next i
f.Close
MsgBox Left(swModel.GetTitle, Len(swModel.GetTitle) - 7) & ".txt file created under working directory"
Exit Sub
error:    MsgBox " please make sure that:" & vbCrLf & _
            "1. Only one SolidWorks session is opened" & vbCrLf & _
            "2. An Assembly or a part is the active document" & vbCrLf & _
            "3. A Sketch feature is selected or active with nothing selected" & vbCrLf & _
            "4. you are allowed to write to working directory.", vbInformation
Exit Sub
