I'm having trouble getting solid bodies to stick together properly. Before I tear out the last of my remaining hair perhaps someone can tell me what's going wrong.
I'm modelling a double cantilever beam with made with two different materials of different thicknesses. I want to model a crack at the free end of the beam and pull the crack apart. To do that I've made each component of the beam into three solid bodies. I can then have no penetration between the surfaces at the end of the beam to simulate the crack and everything else is bonded together, see below.
The contact visualization plot seems OK to me.
..but when I run the analysis
The same lack of bonding is present between the vertical faces of the smaller beam as well.
For each beam I've selected bonded component contact between each of the bodies in each of the beams but I seem to be getting only contact between the horizontal faces even though the visualization tells me the vertical faces are bonded as well.
I just tried and it worked fine in 2017. I would post a picture but it wouldn't take it. I have to run out now Sorry. Bonded default and set the ones you don't want bonded to allow penetration. use a surface to split the part to make the partitions.
