Copy Entities Behaviour
Question asked by Ryan Beck on Feb 18, 2009
Latest reply on Feb 25, 2009 by Ryan Beck
Since recently updating to '09 I have found some unexpected change to the Copy entities feature in drawings...
We use "manual" revision blocks and I normally select the text and lines of a previous revision, then right click, Copy Entities, using existing sketch points as the From/To parameters... It all works normally until I realize that the "To" point didn't "snap" and I end up with a bunch of stuf that is not properly aligned...
The lowest line has a tag extended and the other end is short because instead of snapping to the point, it went somewhere else - even though the mouse icon indicates otherwise.
I have tried with the snap filter on and off - no change. Is there something else that I am missing?
