Solidworks keeps on crashing every time I hit calculate button/ Motion Analysis. Please help
Does this happen with any assembly or just with one particular assembly?
Did this used to work, or did it never work?
Can you Attach an assembly here that exhibits this behavior?
Thomas Bomjan Tamang wrote:
For simplicity, I have only used two parts in this assembly.
I do not see an assembly? I see only a pretty picture.
Why are you using CAD to design and then only pictures to communicate?
Can you attach your assembly here? Yes! No!
Thank you. It is working now,
That is wonderful news.
Can your please post what changed in order for it to now work?
Many people have problems and search the forums for a possible answer. If others have a similar problem to your, you describing the resolution will help future users for generations to come.
Thank you.
May people have problems and search the forums for a possible answer. If others have a similar problem to your, you describing the resolution will help future users for generations to come.
Thank you.
Only a true master of snark can craft a snarky reply so that it's reasonable and as snark goes that answer is pretty reasonable.
Well you may not have gotten the assembly you asked for but at least you got your reply marked correct! Well done!
If I could figure out how to unmark it as the Correct answer - I would.
I did not solve or correctly decipher the OP's question.
As far as I know only the originator of a Discussion, and I assume forum moderators, can do that. On the other hand, at least he didn't mark his own answer as correct, as I've often seen.
Re-reading my reply I can see where you might see it as a criticism. It wasn't meant that way. It was my feeble attempt at being funny.
Sorry if I offended.
I didn't take it as criticism. (After all, I have no control over what the OP does - I couldn't even get the OP to attach the assembly, which, as far as my feeble mind works - would be required to in order to answer the question.)
I understood the intent. (Well, maybe not the humor part - that was pretty feeble.)
