I'd like to be able to convert a spline from one sketch to
another, then remove the relationship and be able to edit the
spline. I can do that and edit the node positions, but I can't get
the handles to edit them fully. Is there a button to push to get
the handles?
Working this way would save time, as I want to make a bunch of curves much like I've already made on a parallel plane, but adjusted a little.
Copy and paste the sketch (CTRL-C & CTRL-V). This will maintain the spline exactly.
Use convert entities, then use the "simplify spline" tool. This will recreate a spline over the current one. It will not necessarily be the same spline as before.
