RunMacro2 errors when running macro.
Question asked by Jeremiah Griffith on May 11, 2018
Latest reply on May 15, 2018 by Deepak Gupta
So, i have a macro with a userform, that I am trying to program so that I can select which macro of a couple different macro's I wan't to run on a particular part.
The Userform is programmed as such:
Option Explicit
Dim runMacroError As Long
Dim boolstatus As Long
Dim MacroPath As String
Private Sub CommandButton1_Click()
MacroPath = "c:\test\test.swp"
boolstatus = swApp.RunMacro2("C:\test\test.swp", "test1", "sl", swRunMacroOption_e.swRunMacroUnloadAfterRun, runMacroError)
Private Sub CommandButton2_Click()
boolstatus = swApp.RunMacro2("C:\test\test.swp", "test1", "tk", swRunMacroOption_e.swRunMacroUnloadAfterRun, runMacroError)
You click on one button and it runs CommandButton1_Click, and the other runs CommandButton2_Click
The c:\test\test.swp is written as follows:
Option Explicit
Dim swmodel As SldWorks.ModelDoc2
Dim fn As Variant
Dim fn2 As String
Dim DIR As String
Sub sl()
Set swmodel = swApp.ActiveDoc
'' Get the Filename, keep everything before the first space from the left, then convert dots to underscores.
fn = swmodel.GetTitle
fn = Split(fn, " ")
fn2 = Replace(fn(0), ".", "_")
'' Set the save directory
DIR = "\\SL\Solid Works\LASER TUBE\SL\SL LSR PART & IGES"
' SHOW MODEL IN ISO - ZOOM TO FIT
swmodel.ShowNamedView2 "*Isometric", -1
swmodel.ViewZoomtofit2
'SAVE COPY OF MODEL IN SW FORMAT AND IGS FORMT TO DIRECTORY PATH DEFINED ABOVE.
swmodel.SaveAs DIR & "\" & fn2 & ".sldprt"
swmodel.SaveAs DIR & "\" & fn2 & ".igs"
swApp.QuitDoc fn2 & ".sldprt"
Sub tk()
fn = Split(fn, " ")
DIR = "\\SL\Solid Works\LASER TUBE\T-K\TK LSR PART & IGES"
When I go to run the CommandClick1 (or 2) for that matter, it errors out saying:
Run-time error '91': Object variable or With block variable not set
Any help would be appreciated, i'm sure it's something stupid that I am just not seeing.
