Hi all,
Can someone point me as to how to obtain the geometry of the surface highlighted below? This is for packaging design so as to achieve a perfect circle when viewing the packaging from the front.
Many thanks
Emily
Hi all,
Many thanks
Emily
Is this a cylindrical package / carton with a circular clear view port to view the interior contents? ...if so, then I'd make a plane offset from the surface, then sketch a circle on the plane that is centered on the axis of the cylinder. Then I'd use a split line to create a new face on the surface. Delete the face, or convert to transparent.
