Re: Hole callout qty not displaying
Shaodun LinMay 10, 2018 11:33 AM (in response to Dennis Ousley)
Please check if you have calloutformat.txt located in <install_dir>\solidworks\lang\<language>
Dennis Ousley May 10, 2018 12:02 PM (in response to Shaodun Lin)I do have that file and I double checked to make sure Solidworks was looking to the correct file location.
Derrick Docherty May 11, 2018 9:28 AM (in response to Dennis Ousley)running 2018 and got the same issue. I also have the callout file and its made no difference.
Chris Saller May 11, 2018 9:30 AM (in response to Dennis Ousley)Are the points in the same sketch?
Dennis Ousley May 14, 2018 9:57 AM (in response to Chris Saller)For the most part, yes.
Dennis Bacon May 11, 2018 10:36 AM (in response to Dennis Ousley)-
Dennis Ousley May 14, 2018 9:58 AM (in response to Dennis Bacon)Yes I have used the hole wizard for everything.
Dennis Bacon May 14, 2018 10:11 AM (in response to Dennis Ousley)
Dennis Ousley May 30, 2018 4:33 PM (in response to Dennis Ousley)So what I have discovered is that the parts the quantity are not displaying for are parts of a weldment that have been inserted in to new parts, then had drawings made. The holes were added in the original model. If I insert the body in to a new part THEN add the holes, the quantity shows up in the drawing. Not sure why that is or how to get around the issue...
Solid Air May 30, 2018 5:46 PM (in response to Dennis Ousley)So why do you not model part as one weldment instead of inserting parts? (At least where I work) when a part is inserted, it has it's own part number and drawing.
Dennis Ousley May 31, 2018 9:01 AM (in response to Solid Air)I'm just modeling from the top down. Start as one weldment and then break out subassemblies and so forth as needed. Just leaves one model to make changes to. Just seems hole callout info does not transfer to the new parts.
