NPNilesh Patel09/05/2018
Hi All,
I have started learning PDM APIs and created a macro to get the latest version of the active document in SolidWorks, but I am not able to get the latest vesion. Here are the codes:
Option Explicit
    Dim swApp           As SldWorks.SldWorks
    Dim swModel         As ModelDoc2
    Dim swVault         As EdmVault5
    Dim swVault7        As IEdmVault7
    Dim swFile          As IEdmFile5
    Dim swFile12        As IEdmFile12
    Dim swFolder        As IEdmFolder5
    Dim swParFolder     As IEdmFolder5
    Dim swPos           As IEdmPos5
    Dim swSelFiles(0)   As EdmSelItem
    Dim swBatchGet      As IEdmBatchGet
    Set swVault = New EdmVault5
    Set swModel = swApp.ActiveDoc
    Debug.Print swModel.GetPathName
    If swVault.IsLoggedIn = False Then swVault.LoginAuto "Vault_Name", 0
    Set swFile = swVault.GetFileFromPath(swModel.GetPathName, swParFolder)
    Set swFile12 = swFile
    Debug.Print swFile.CurrentVersion
    Debug.Print swFile12.GetLocalVersionNo2(swModel.GetPathName, False)
    Set swPos = swFile.GetFirstFolderPosition
    Set swFolder = swFile.GetNextFolder(swPos)
    Debug.Print swFolder.LocalPath
    swSelFiles(0).mlDocID = swFile.ID
    swSelFiles(0).mlProjID = swFolder.ID
    Set swVault7 = swVault
    Set swBatchGet = swVault7.CreateUtility(EdmUtil_BatchGet)
    swBatchGet.AddSelection swVault, swSelFiles
    swBatchGet.CreateTree 0, EdmGetCmdFlags.Egcf_SkipExisting
    If swBatchGet.ShowDlg(0) = True Then swBatchGet.GetFiles 0, Nothing
    'swBatchGet.GetFiles 0, Nothing
Below are the links of couple of forum I used as reference:
Solidworks EPDM 'Get latest' from VBA - Stack Overflow
You can see the codes are quite similar but for some reason, I am not able to get the latest version of the document. I can get the local version (IEdmFile12::GetLocalVersionNo2) and the current version (IEdmFile5::CurrentVersion) of the document correctly but not able to get the latest version.
I have already tried following:
1. Passing the full document path instead of IModelDoc2::GetPathName.
2. swSelFiles(0).mlDocID = 0 instead of swSelFiles(0).mlDocID = swFile.ID.
3. swSelFiles(0).mlProjID = ("Folder Path").ID instead of swSelFiles(0).mlProjID = swFolder.ID &
4. swBatchGet.CreateTree 0, EdmGetCmdFlags.Egcf_Nothing instead of swBatchGet.CreateTree 0, EdmGetCmdFlags.Egcf_SkipExisting
But I am still not able to get the latest version of the active document in SolidWorks. What am I missing? I know there are plenty of PDM API gurus here, would someone be able to guide me?
Thanks in advance.
Regards,
Nilesh
