10 Replies Latest reply on May 11, 2018 9:46 AM by Jacob Corder
    Drawing view - How can I get displayed components only?
    William Cruz
      I have a drawing with multiple views, the assembly that the drawing was created from has some components that are not shown via an extrude-cut feature, they are not hidden or suppressed in the feature tree but they are not visible in the mode view. When I use:
      swThisView.GetVisibleComponents();
      It returns everything, all the components even though they are not in the drawing view. This is how I get my drawing views:
              internal List<View> swGetAllDwgViews()
                  List<View> lstSwViews = new List<View>();
                  try
                      object[] swAllDwgViews = (_swDwgDoc.GetCurrentSheet()).GetViews() as object[];
                      if (swAllDwgViews != null)
                          foreach (View swDwgView in swAllDwgViews)
                              lstSwViews.Add(swDwgView);
                      return lstSwViews;
                  catch (Exception ex)
                      return lstSwViews;
      I've tried going directly to the RootComponent of the drawing view and processing it that way but I still get all the components, including those hidden by the extrude cut feature.
        • Re: Drawing view - How can I get displayed components only?
          Alex Burnett
          I don't know how much this helps but perhaps the workflow in this macro can be modified to work for you.
          This iterates through all views in a drawing and hides on the drawing level any sketches that are shown. It does require that the part or assembly file be open in order to do so.
          Rather than iterating through the feature tree to see what sketch is shown, you would have to iterate through the feature tree to see what bodies are shown.
          Hiding sketches from the design tree for a particular selected view
            Abilash V.
            'drView.GetVisibleComponents- should  directly help you.
            ' By the way the following macro helps to traverse selected drawing view and selects the sketches in that,May be u can modify it. if you want more help ,feel free to ask.
            'Link for macro .: https://abilashv.blogspot.in/2018/05/solidworks-macro-to-hideshow-sketch-in.html
            Dim swmodel As SldWorks.ModelDoc2
            Dim bool As Boolean
            Dim swfeatmgr As SldWorks.FeatureManager
            Dim rootnode As SldWorks.TreeControlItem
            Dim swnode As SldWorks.TreeControlItem
            Dim swchildnode As SldWorks.TreeControlItem
            Dim swfirstnode As TreeControlItem
            Dim swfinalnode As SldWorks.TreeControlItem
            Dim fnalfeature As SldWorks.TreeControlItem
            Dim fnalfeature1 As SldWorks.TreeControlItem
            Dim longstat As Long, war As Long
            Dim swselmgr As SldWorks.SelectionMgr
            Dim swfeat As SldWorks.Feature
            Dim swview As SldWorks.View
            Dim prt As SldWorks.ModelDoc2
            Set swmodel = swApp.ActiveDoc
            Set prt = swApp.ActiveDoc
            Set swfeatmgr = swmodel.FeatureManager
            Set rootnode = swfeatmgr.GetFeatureTreeRootItem2(0)
            Set swselmgr = swmodel.SelectionManager
            Set swview = swselmgr.GetSelectedObject6(1, -1)
            Debug.Print rootnode.Text
                If Not rootnode Is Nothing Then
                Set swnode = rootnode.GetFirstChild
                Debug.Print swnode.Text
                    While Not swnode Is Nothing
                    Set swfirstnode = swnode.GetFirstChild
                        While Not swfirstnode Is Nothing
                        Debug.Print swfirstnode.Text
                        Set swchildnode = swfirstnode.GetFirstChild
                         If swview.Name = swfirstnode.Text Then
                            While Not swchildnode Is Nothing
                            Debug.Print swchildnode.Text
                            '*****************************************if loop
                            Set swfinalnode = swchildnode.GetFirstChild
                                While Not swfinalnode Is Nothing
                                Debug.Print swfinalnode.Text
                                Set fnalfeature = swfinalnode.GetFirstChild
                                    While Not fnalfeature Is Nothing
                                    Debug.Print fnalfeature.Text
                                    Set fnalfeature1 = fnalfeature.GetFirstChild
                                        While Not fnalfeature1 Is Nothing
                                        Debug.Print fnalfeature1.Text
                                        Set swfeat = fnalfeature1.Object
                                        If swfeat.GetTypeName2 = "ProfileFeature" Then
                                        bool = swfeat.Select2(True, -1)
                                     '   prt.ClearSelection2 True
                                      '  swmodel.ForceRebuild3 False
                                        swApp.Visible = True
                                        Set fnalfeature1 = fnalfeature1.GetNext
                                        Wend
                                    Set fnalfeature = fnalfeature.GetNext
                                    Wend
                                 Set swfinalnode = swfinalnode.GetNext
                                Wend
                            Set swchildnode = swchildnode.GetNext
                            Wend
                        Set swfirstnode = swfirstnode.GetNext
                        Wend
                    Set swnode = swnode.GetNext
                    Wend
            prt.BlankSketch
            prt.ForceRebuild3 False
            MsgBox "COMPLETED", vbDefaultButton1
            'Regards
            'Abilash
              Jacob Corder
              getvisiblecomponents does not take into account displaystates. so if they are hidden in a displaystate
              so what you have to do is
              kick solidworks in the face,  and then proceed to do this
              for each component you need to get the view, then get the modeldoc, then get the displaystate from the view,  then get the displaystatesetting from the assembly.
              oh and you have to activate that display state in the assembly to perform the check to see if it is visible.
              pretty great huh......
                Jacob Corder
                ok. so i have created a few extensions that you can use.
                i was wrong about activating the display state.   that was for checking if the component is exploded in a display state.
                 <Extension()>
                    Function GetVisibilityInDisplayState(ByVal SwComponent As Component2, ByVal DisplayStateName As String) As swComponentVisibilityState_e
                        If SwComponent Is Nothing Then Return swComponentVisibilityState_e.swComponentUnknown
                        Dim VisVals As Object = SwComponent.GetVisibilityInAsmDisplayStates(swDisplayStateOpts_e.swSpecifyDisplayState, New String() {DisplayStateName})
                        If VisVals Is Nothing Then Return swComponentVisibilityState_e.swComponentUnknown
                        If VisVals(0) = swComponentVisibilityState_e.swComponentVisible Then
                            Return swComponentVisibilityState_e.swComponentVisible
                        Else
                            Return swComponentVisibilityState_e.swComponentHidden
                    End Function
                <Extension()>
                    Function IsVisibleInView(ByVal SwDrawingComponent As DrawingComponent) As swComponentVisibilityState_e
                        If SwDrawingComponent Is Nothing Then Return swComponentVisibilityState_e.swComponentUnknown
                        If SwDrawingComponent.Visible = False Then
                        Dim SwView As View = Nothing
                        Dim SwComp As Component2 = Nothing
                        Try
                            SwView = SwDrawingComponent.View
                            If SwView Is Nothing Then Return False
                            Dim DispStateName As String = SwView.DisplayState
                            If Len(Trim(DispStateName)) > 0 Then
                                SwComp = SwDrawingComponent.Component
                                Return SwComp.GetVisibilityInDisplayState(DispStateName)
                            Else
                        Catch ex As Exception
                        Finally
                            '  you should really release references to objects, marshal.releaseCOMObject(swview)
                             ' marshal.releaseCOMObject(SwComp)
                        End Try
                    End Function
                    William Cruz
                    I get two exceptions and SW force-closes when I run the below code. I code in c# but it's a direct translation except all I need is a Bool as a return value - something I noticed in your code is that SwComp is never assigned a value before sending it off to "GetVisibilityInDisplayState" , So I get the swDwgComp.Component and use that.
                    The exceptions occur when calling "GetVisibilityInAsmDisplayStates"
                    Exception thrown: 'System.AccessViolationException'
                    Exception thrown: 'System.Reflection.TargetInvocationException'
                        internal static bool IsVisibleInView(this DrawingComponent swDwgComp)
                            View swView = swDwgComp.View;
                            try
                                if (!swDwgComp.Visible)
                                    return false;
                                if (swView != null)
                                    string strDispStName = swView.DisplayState;
                                    if (!string.IsNullOrEmpty(strDispStName))
                                        return (swDwgComp.Component).GetVisibilityInDisplayState(strDispStName);
                                    else
                                        return true;
                                else
                                    return false;
                                /*handle error*/
                                return false;
                            finally
                                Marshal.ReleaseComObject(swView);
                        internal static bool GetVisibilityInDisplayState(this Component2 swComp, string strDispStName)
                            try
                                object[] AsmDisplayStates = swComp.GetVisibilityInAsmDisplayStates(
                                    (int)swDisplayStateOpts_e.swSpecifyDisplayState,
                                    new object[1] { strDispStName });
                                if (AsmDisplayStates != null)
                                    if ((swComponentVisibilityState_e)AsmDisplayStates[0] ==
                                        swComponentVisibilityState_e.swComponentVisible)
                                        return true;
                                    else
                                        return false;
                                else
                                    return false;
                                /*handle errors*/
                                return false;
                            finally
