I have a feature in a part that is defined in context of an
assy and I want that dimensions to be displayed in a DT. Not to
control those dimensions just for display.
I try to use an equation (A="D@...") and a config custom prop. that refers to A but in DT the value of that prop is not changed accordingly.
I presume that is no solution for that becouse in sw DT is for controling the part not for display informations but ....
but the first think I do is dbl-click and as you see in attached image only the prop. are displayed.
SW 2008 sp5.0
MS Excel 2007
For the other dim dbl click works fine.
There are other settings to insert driven dim in DT?
If you are refering to "DimensionNames" when you say "prop.", then yes, that would be the column heading. Below that are numbers or values for each configuration.
So what is your question/issue?
