Is it possible to create surface by sweeping the blue arc around the axis following rectangular path? (see attached picture)@
I'm new to Solidworks, I've tired swept surface but so far no luck with creating proper surface around the axis.
I've used to work with I-DEAS NX where I had variational sweep surface feature to make this work.
Any advice?
This may not work as surface would interfere with itself, causing the failure.
You can try one of the below methods:
1. Split the arc near the top side and create a circle there, Use that circle and the below rectangular sketch for the sweep. An then fill the inner circle entry area.
2. Create the other section and use that to loft the two sections
