Pack and Go Macro - Overwrite = False
Question asked by Brett Tighe on May 4, 2018
I need some help with the simple macro of pack and going. Currently have it running in excel where I can change what assemblies get pack and go'ed and the prefix. Everything works great until two different assemblies get pack and go'ed into the same folder with parts of the same name. How do I get the "Confirm File Replace" prompt into VBA to set it to False?
Code below
Option Explicit
Dim swModelDoc As SldWorks.ModelDoc2
Dim swModelDocExt As SldWorks.ModelDocExtension
Dim swPackAndGo As SldWorks.PackAndGo
Dim openFile As String
Dim pgFileNames As Variant
Dim pgFileStatus As Variant
Dim pgGetFileNames As Variant
Dim pgDocumentStatus As Variant
Dim status As Boolean
Dim warnings As Long
Dim errors As Long
Dim i As Long
Dim namesCount As Long
Dim myPath As String
Dim statuses As Variant
' Open assembly
openFile = Range("B2")
Set swModelDoc = swApp.OpenDoc6(openFile, swDocASSEMBLY, swOpenDocOptions_Silent, "", errors, warnings)
Set swModelDocExt = swModelDoc.Extension
' Get Pack and Go object
Debug.Print "Pack and Go"
Set swPackAndGo = swModelDocExt.GetPackAndGo
' Get number of documents in assembly
namesCount = swPackAndGo.GetDocumentNamesCount
Debug.Print "  Number of model documents: " & namesCount
' Include any drawings, SOLIDWORKS Simulation results, and SOLIDWORKS Toolbox components
swPackAndGo.IncludeDrawings = True
Debug.Print "  Include drawings: " & swPackAndGo.IncludeDrawings
swPackAndGo.IncludeSimulationResults = True
Debug.Print "  Include SOLIDWORKS Simulation results: " & swPackAndGo.IncludeSimulationResults
swPackAndGo.IncludeToolboxComponents = True
Debug.Print "  Include SOLIDWORKS Toolbox components: " & swPackAndGo.IncludeToolboxComponents
' Get current paths and filenames of the assembly's documents
status = swPackAndGo.GetDocumentNames(pgFileNames)
Debug.Print ""
Debug.Print "  Current path and filenames: "
If (Not (IsEmpty(pgFileNames))) Then
    For i = 0 To UBound(pgFileNames)
        Debug.Print "    The path and filename is: " & pgFileNames(i)
    Next i
' Get current save-to paths and filenames of the assembly's documents
status = swPackAndGo.GetDocumentSaveToNames(pgFileNames, pgFileStatus)
Debug.Print ""
Debug.Print "  Current default save-to filenames: "
    Next i
' Set folder where to save the files
myPath = Range("B3")
status = swPackAndGo.SetSaveToName(True, myPath)
' Flatten the Pack and Go folder structure; save all files to the root directory
swPackAndGo.FlattenToSingleFolder = True
' Add a prefix and suffix to the new Pack and Go filenames
swPackAndGo.AddPrefix = Range("B1")
swPackAndGo.AddSuffix = ""
' Verify document paths and filenames after adding prefix and suffix
ReDim pgGetFileNames(namesCount - 1)
ReDim pgDocumentStatus(namesCount - 1)
status = swPackAndGo.GetDocumentSaveToNames(pgGetFileNames, pgDocumentStatus)
Debug.Print ""
Debug.Print "  My Pack and Go path and filenames after adding prefix and suffix: "
For i = 0 To (namesCount - 1)
     Debug.Print "    My path and filename is: " & pgGetFileNames(i)
Next i
' Pack and Go
statuses = swModelDocExt.SavePackAndGo(swPackAndGo)
' Close file
swApp.CloseDoc (Range("B2"))
