This content has been marked as final.
Show 7 replies
Re: Can I copy and paste material?
Rubén Rodolfo Balderrama May 4, 2018 8:40 AM (in response to Deepak Gupta)Deepak is there a macro for make one match properties to make this one?
Deepak Gupta May 4, 2018 9:50 AM (in response to Rubén Rodolfo Balderrama)Ruben, could you please explain in details as I'm not quite sure on what you looking for?
Rubén Rodolfo Balderrama May 4, 2018 12:28 PM (in response to Deepak Gupta)Well for example when I copy an appearance property and paste it into a new component that would make a match properties.
Imagine if you could copy the material property of a component and just paste through the components of an assembly. It would be easier to walk opening each component and select it from a list.
The video is only to show you a example
Match Property.wmv 6.2 MB
Deepak Gupta May 4, 2018 9:54 AM (in response to Dan Pihlaja)Dan, I do not think that is limitation but an option in case you want to replace material only for parts with some material specified.
