Is it possible in an assembly to see (check) if all components have a material assigned, preferably in the tree? I know if the parts are expanded it shows the material. I would like a quick way to know without having to check each component, sub component, etc. This would help in doing Mass properties easily.
Thanks.
Jay
Yes:
1) Use Assembly Visualization
2) Change a column (select "More")
3) Change to SW-Material
Then sort by that column.
