Anyone noticing that hole wizard features are not getting
updated correctly if they have an out of context reference? This is
about the 5th time I've had to go to the hole wizard feature in a
sub-assembly that is in the context of a higher level assembly and
edit the feature to get it to update correctly. Ctrl+B and Ctrl+Q
have no impact!
This doesn't resolve the out of context problem but it will go away without messing up you model.
I found that a quick, not pretty, but reliable solution is to:
1. Go to the sketch that is out of context
2. Select all
3. Click display/delete relations in the sketch command ribbon
4. Holding Ctrl, click all relations with a ? beside them
5. Delete them
6. Use the fully define sketch function
Your sketch wont be out of context and it will now be fully defined
