Having an issue with composer file links. When going from one file to another, the links work fine. When I go back the links disappear. Any suggestions or workarounds? I have re-done the links, re-added, the files, and added them to the animation views. It almost seems like the links are referencing a later version of the file, but it still removes the links even if there is only one version or if i have latest version.
Thanks.
Hi Jonny,
it is not possible to answer without concrete Infos.
Which type of link do you use?
Post any of the links as you use it.
Which filetype do you mean? SVG? Or do you refer inside the Player from one to the next view?
What do you mean with "animation views"?
Is it possible to attache the smg file?
Regards Dirk
