One of the things that I truly miss in Solidworks (unless someone tells me it does exist and I haven't found it in 9 years) is the "Repeat last command option" for the right mouse button in ACAD. Yes, I will tie this into the mouse gestures in a quick second.
Do any of you actively use mouse gestures? If so, how long did it take you to get used to using them and how do you think it helped with your overall productivity? I have tried using them, even to the point of customizing the options, but I continually forget that they are there.
So, I am contemplating as to whether, or not, I want to try and get them back up and going...but I also wanted to know if there was a command similar to the "repeat last command" that can be implemented into the gesture menu?
I use them extensively, and don't remember any problems getting used to them. However, I didn't come from AutoCAD so that might have some bearing, and I don't like keyboard shortcuts (one hand on my regular mouse and one on the 3d mouse) .
As far as "repeat last command", as I said, I'm not familiar with AutoCAD, but if you hit Escape to close out a command in SW, then hitting Enter will reactivate it (and no, as far as I know you can't set Enter as a Mouse Gesture). Edit: I was wrong. You can.
