API Loop for each open document
Question asked by Frédéric Leclercq on Apr 30, 2018
Latest reply on May 2, 2018 by Amen Allah Jlili
Hello
I'm new user here.
I'm an french user so , sorry for lot of errors
I copied and modified an existing API about printing.
I open a drawing and the macro select the good printer according to the format.
It's ok for one document.
But now, I want to modify this API to print all open drawings
I don't understand where to put the loop
during my tests, it prints 2 or 3 times the same drawing
My single code below (dirty I know )
Thanks for your help
Dim swApp As Object
Dim Part As Object
Dim boolstatus As Boolean
Dim longstatus As Long
Dim Annotation As Object
Dim Gtol As Object
Dim DatumTag As Object
Dim FeatureData As Object
Dim Feature As Object
Dim Component As Object
Dim Paperformat As Variant 'defining paperformat
Dim Printer_no1 As Variant 'defining printer no. 1 (laserprinter)
Dim Printer_no2 As Variant 'defining printer no. 2 (plotter)
Dim A4 As Variant
Dim A3 As Variant
Dim A2 As Variant
Dim A1 As Variant
Dim A0 As Variant
Dim swAppl As SldWorks.SldWorks
    Dim swSheet As SldWorks.Sheet
    Dim vSheetProps As Variant
    Dim bRet As Boolean
Const swPrintPaperSize = 0
Const swPrintOrientation = 1
Const vbPRORPortrait = 1
Const vbPRORLandscape = 2
Sub print_selected_paperformat() 'macro modified by FL
Dim swApp As Object
Dim Part As Object
'Set printer path and name
Let Printer_no1 = "HP LaserJet 5200 Series PCL 5" 'nom de l'imprimante A3 dans l'explorateur Windows récupéré
Let Printer_no2 = "HP Designjet 500 42+HPGL2 Card at //dlink-9324C3/dlk-9324C3-P1" 'plotter HP plans A1 A0
'Set paperformats
Let A4 = 9
Let A3 = 8
Let A2 = 54
Let A1 = 621
Let A0 = 622
Set Part = swApp.ActiveDoc
Set swAppl = Application.SldWorks
    Set swModel = swAppl.ActiveDoc
    Set swDraw = swModel
    Set swSheet = swDraw.GetCurrentSheet
vSheetProps = swSheet.GetProperties
    MsgBox (vSheetProps(0)) 'aperçu du numéro si OK
Paperformat = vSheetProps(0)
If Paperformat = 8 Then GoTo printformat_a4 Else
If Paperformat = 8 Then GoTo printformat_a3 Else
If Paperformat = 9 Then GoTo print_fit_a3 Else
If Paperformat = 10 Then GoTo printformat_a1 Else
If Paperformat = 11 Then GoTo printformat_a0 Else
If Paperformat = 5 Then GoTo print_fit_a3 Else GoTo End_routine
End
'subroutines depending on papersize
printformat_a4:
Printer = Printer_no1
Part.PrintSetup(swPrintOrientation) = vbPRORPortrait
Let Paperformat = A4 '#9 = A4 on laserprinter laserjet 5200
swApp.ActivePrinter = Printer
Part.PrintSetup(swPrintPaperSize) = Val(Paperformat) 'Enable selected Paperformat A4
GoTo Print_finally_drawing
printformat_a3:
Part.PrintSetup(swPrintOrientation) = vbPRORLandscape
Let Paperformat = A3 '#8 = A3 on laserprinter laserjet 5200
Part.PrintSetup(swPrintPaperSize) = Val(Paperformat) 'Enable selected Paperformat = A3
printformat_a2:
Part.PrintSetup(swPrintPaperSize) = Val(Paperformat) 'Enable selected Paperformat A3 instead of A2
printformat_a1:
Printer = Printer_no2
Let Paperformat = A1
Part.PrintSetup(swPrintPaperSize) = Val(Paperformat) 'Enable selected Paperformat A1
printformat_a0:
Part.PrintOut2 1, 1, 1, False, Printer, 0#, False, ""
GoTo End_routine
print_fit_a3:
'Part.PrintPreview 'ONLY FOR TEST
GoTo End_routine
Print_finally_drawing:
Part.PrintOut2 1, 1, 1, False, Printer, 1#, False, ""
GoTo End_routine
End_routine:
'Values for the Laserjet 5200
'Value  Paper size
'8 A3 (297 x 420 mm)
'9 A4 (210 x 297 mm)
'54 A2
'Values for the traceur HP
'Value  Paper size
'621 A1 (594 x 841mm)
'622 A0 (841 x 1189mm)
