Not sure what tutorial you are referring to. Try making the tutorial window active then press and hold the Ctrl key then press the plus key. You can also put your mouse cursor inside the window, press and hold the Ctrl key then use the mouse wheel to scroll in and out. Not all windows do this but it is worth a try.
Hi Solid Air,
Now that's a cool little trick..........
One of those times that I benefit from being wrong, thanks!
Dave.
