All,
I'm try to write an equation that will suppress/unsuppress specific configurations of a part from the assembly. I can get the part to suppress/unsuppress in the assembly, but I can't figure out how to get a different configuration to do the same. I believe I just need the correct syntax for the feature name. Below is equation I have so far.
The model is two bearing blocks and two support rods. When the distance of the bearing blocks change the support rods change. I'm trying to make where the support rods will automatically change when the bearing blocks move. The support rods were created using a design table.
Try this:
