The Macro below saves the selected body (of a part) into a STL file.
I have been using it in SW2017 on a daily basis, but after upgrading to SW2018 it stopped working...
It now saves an empty STL file of 1 kB. Does anybody know what goes wrong?
Option Explicit
Dim swBody As SldWorks.Body2
Set swModel = swApp.ActiveDoc
Set swBody = swSelMgr.GetSelectedObject6(1, -1)
Dim FilePath As String
Dim NewFilePath As String
Dim ConfigName As String
Dim BodyName As String
'Save the active model
swModel.Save3 0, 0, 0
'Check if the the active model is a PART and if there is a solid body selected
If swModel.GetType = swDocPART Then
If swBody Is Nothing Then
MsgBox "Please select a solid Body"
Else
FilePath = swModel.GetPathName
ConfigName = swApp.GetActiveConfigurationName(FilePath)
BodyName = swBody.Name
NewFilePath = Left(FilePath, InStrRev(FilePath, "\")) & ConfigName & " [" & BodyName & "]" & ".STL"
swModel.SaveAs2 NewFilePath, 0, True, False
MsgBox "van Cronenburg 3D Print STL saved." & vbNewLine & vbNewLine & "Filename: " & ConfigName & " [" & BodyName & "]." & "STL"
Kind regards,
Thomas
