Add custom column with formula to BOM table
Question asked by Yash Kothari on Apr 27, 2018
Latest reply on May 22, 2018 by Yash Kothari
I am struggling to insert a formula in a custom defined column to BOM table. I found a program of adding a partnumber column from SolidWorks help.
2018 api - Insert Part Number Column in BOM Table Example (VBA)
__________________________________________________________
Option Explicit
Dim boolstatus As Boolean
Dim SelMgr As Object
Dim theTableAnnotation As SldWorks.TableAnnotation
Dim SelObjType As Long
Dim TableAnnotationType As Long
Sub DisplayTableColumnProps(theTableAnnotation As Object)
    Dim ColCount As Long
    Dim i As Long
    Dim ColType As swTableColumnTypes_e
    Dim ColTitle As String
    Debug.Print "Col#"; vbTab; "Type"; vbTab; "Title"
    ColCount = theTableAnnotation.ColumnCount
  For i = 0 To ColCount - 1
        ColType = theTableAnnotation.GetColumnType(i)
        ColTitle = theTableAnnotation.GetColumnTitle(i)
        Debug.Print i; vbTab; ColType; vbTab; ColTitle
    Next i
    Set swModel = swApp.ActiveDoc
    Set SelMgr = swModel.SelectionManager
    SelObjType = SelMgr.GetSelectedObjectType3(1, -1)
    If SelObjType <> swSelANNOTATIONTABLES Then
        MsgBox "Select a BOM table in the drawing before running this example."
        End
    Set theTableAnnotation = SelMgr.GetSelectedObject6(1, -1)
    TableAnnotationType = theTableAnnotation.Type
    If TableAnnotationType <> swTableAnnotation_BillOfMaterials Then
        End
    Debug.Print "Table before inserting a column..."
    ' Display table before inserting a column
    DisplayTableColumnProps theTableAnnotation
    ' Insert new column
    boolstatus = theTableAnnotation.InsertColumn2(swTableItemInsertPosition_Last, 0, "Add Item No", swInsertColumn_DefaultWidth)
    boolstatus = theTableAnnotation.SetColumnType(theTableAnnotation.ColumnCount - 1, swBomTableColumnType_ItemNumber)
    Debug.Print " "
    Debug.Print "Table after inserting a column..."
    ' Display table after inserting a column
____________________________________________________________________
But now i need to insert a new column containing a formula of adding the numeric values of item number (in detailed indented BOM). I need a Macro, help please.
Deepak Gupta
