Hi
when i edit or modify existing flange of my model my flat pattern view changes .
please check attached images.
Raj
Hi
Raj
Raj,
If you can post an image of your feature tree on the part model it will help us troubleshoot this with you.
Check your Flat Pattern configuration on your sheet metal part. Make sure that the model flattens when the flat pattern configuration is activated.
You may need to unsupress the Flat-Pattern1 feature underneath the Flat-Pattern Feature at the end of the feature tree if your part does not flatten when the flat pattern configuration is activated.
As suspected/stated by Joe Ourada, the flat pattern feature is suppressed.
Unsuppress it and that should fix the issue.
Hi
If I unsuppressed it, it becomes flat but in drafting it shows flat.
I am attaching link of that part please check .
please go in drafting and check the Flat pattern view.
https://www.sendspace.com/file/dplhnh
Raj
Hi Raj,
I have seen your model. First Open your part and go to configuration manager. You have seen your active configuration (Default SM-Flat-PATTERN) "Unsuppress the Flat Pattern in this configuration."
After That, again go to Configuration manager and activate Configuration (Default [Outer Profile-Rev-01]) "Suppress the FlatPattern in this configuration".
Save the part. and make drawing.
After that, your problem has been resolved.
Please attach the files in the forum only. How can I attach a file to a forum post?
And regarding your issue, kindly look at the instructions/suggestions carefully, you need to unsuppress the flat pattern feature and not the configuration.
Activate the flat pattern configuration, go back to model tree and unsuppress the flat pattern feature.
Hi Gaurav .
I have already unsuppressed it but I goes flat in my assembly also.
I am attaching link of 3d model and drawing please check when drafting at the place of flat pattern
view it shows front view.
https://www.sendspace.com/file/0o0167
Raj
Raj,
