There are like 34 parts in the BOM Table which make really difficult to read and see the components ( exploded graphics) in one page , It would be better if I can show the BOM Table and exploded graphics in different page.
this make no sense. But yes it is possible.
Create a view with both, exploded view and BOM.
move the bom out of the papersize and position your exploded view
Create a new view as an copy. Now move the exploded view (geometry) out of the papersize and the BOM back to the view.
Better:
create the view, afterwards SVG's or JPG's and use the layoutsoftware (word or indesign).
Also create the BOM and Export it as an .csv and use this as well in the layout Software.
Position them and than create your document.
If you want to create interactive SVG's without a PDF document, don't use BOM
Create the Label or callouts directly with those Infos you see in the BOM table. In this case you can use but you need no pos.no. for the labels.
Step 1: Create a View with both, exploded view and BOM
Step 2: Copy View 1 to View 2
Step 3: to hide the BOM or the Callouts in a view -> set the transparency (lucency) from 255 to 0
Note: If you deactivate the Callout in the cooperation (deactivate the hook in the box) -> the part-line is "deleted" in the BOM of the specific part
PS: I used/found this yesterday on my own
Not 100% clear on what you are trying to do but any reason why you can't just create another view giving you another "page"? Can you attach some screenshots on what you are currently getting and what you are trying to do so we can better advise you?
Cheers,
Derek
