MMMason Morton25/04/2018
I've searched and found that some have asked a similar question before but none have a good answer. I have some holes that need to be inspection dimensions. On some of the holes, the first and second line get circled and on others, just the first line gets circled. I can't find what the difference is! I need for both lines to be circled.
In both cases, the hole is created in the part by using an extruded cut (not a hole feature).
Also I noticed when you select the dimensions that have just a single line circled, a button to open this dimension formatting window pops up, whereas it doesn't on the dimensions that have both lines circled. Not sure what that's all about.
Thanks!
