I have a pipe bend and forces and moments from Caesar, how do I fix the pipe to see what the effects will be on the smaller stubs on the pipe.
Question asked by Valesca Cronje on Apr 25, 2018
The section of pipe is modeled in Caesar II and the forces from this I want to input in Solidworks and do an analysis to see what will happen to the pipe and the small stubs. My question is how do I fix the pipe correctly to model it? The pipe is connected to other pipes on both ends. I am only concerned with this section of pipe. ID is 500mm, wall thickness 14mm. The internal temperature is 545 degrees Celsius and the  pressure is 4.9 MPa.
