PDM Pro - Copy Variable Values from Active Config to Others Using Button
Question asked by Michael Dekoning on Apr 21, 2018
Latest reply on Apr 23, 2018 by Jacob Corder
I am working on an add-in to copy variable values from the active tab to the other card tabs using a button. I have run across an issue. Using IEdmEnumeratorVariable5.GetUpdateVars() or IEdmEnumeratorVariable7.GetVersionVars() was crashing Windows Explorer.
            try
                switch (poCmd.meCmdType)
                    case EdmCmdType.EdmCmd_CardButton:
                        if (poCmd.mbsComment == "Copy Var Values")
                            EdmCmdData ecd = (EdmCmdData)ppoData.GetValue(0);
                            string activeconfigname = ecd.mbsStrData1;
                            IEdmFile5 file = edmVault.GetObject(EdmObjectType.EdmObject_File, ecd.mlObjectID1) as IEdmFile5;
                            IEdmEnumeratorVariable5 evar = (IEdmEnumeratorVariable5)poCmd.mpoExtra;
                            object[] valuelist = null;
                            evar.GetUpdateVars(ecd.mlObjectID2, out valuelist);
                            IEdmStrLst5 cfgs = (IEdmStrLst5)ecd.mpoExtra;
                            //UpdateVariables(ecd.mlObjectID2, activeconfigname, file, evar, cfgs);
                        break;
When I added code to capture the error I received the following message.
It would appear that this only occurs when using either of these methods from a data card button.  Has anyone else seen this and is there a workaround?
