Re: Is it possible to set the base of an ordinate dimension to use the same precision as the document? By default it is set to zero decimal places.
Tony Tieuli Apr 20, 2018 11:56 AM (in response to Scott Perman)Scott Perman wrote:
You can change the precision of the base in the dimension dialog.
All I did was click on the base line then changed the precision before I clicked to place the dimension.
You can change the precision of each individual dimension as well.
Scott Perman Apr 20, 2018 12:25 PM (in response to Tony Tieuli)I want it to be 3 decimal places by default. I'm tired of changing it every time.
Britt Kessler Apr 20, 2018 12:30 PM (in response to Scott Perman)Scott Perman wrote:
I suggest modifying your drawing template dimensions setting. Options>Document Properties>Dimensions>Primary precision>.123
Save it out as a .DRWDOT file
Tony Tieuli Apr 20, 2018 12:44 PM (in response to Britt Kessler)Britt Kessler wrote:
I don't believe that will work.
The first thing I tried was to set that setting to .123. When I then did an ordinate dimension the base dimension was still 0.
Glenn Schroeder Apr 20, 2018 12:36 PM (in response to Scott Perman)Scott Perman wrote:
You can try the method Britt Kessler suggested, but if I'm not mistaken you'd need to set Trailing zeros to "Show", and I'm getting the message shown below when I try to do that, so it might not work.
If it doesn't I'd suggest setting one dimension the way you want it and save it as a Style. Then it will be very easy to apply it to other dimensions in the future. If you like it you could add it to your drawing templates so it's already set up in new Drawings.
Dan Pihlaja Apr 20, 2018 12:47 PM (in response to Glenn Schroeder)This is what I do. I have it set as a style. I like the 0 dimension to POP on the drawing, so I bold it and give it 3 decimal places.
Scott Perman Apr 20, 2018 2:28 PM (in response to Glenn Schroeder)I have it set to show trailing zeros. The precision is set to "none"
Scott Perman Apr 20, 2018 2:30 PM (in response to Glenn Schroeder)I haven't used styles before. I'll have to look into those. I'm not sure changing the style is any easier than just changing it to 3 decimal places.
Deepak Gupta Apr 20, 2018 12:40 PM (in response to Scott Perman)What a difference 0 and 0.000 would make.
