Selecting sketch segment from a user form
Question asked by Harold Black on Apr 20, 2018
Latest reply on Apr 24, 2018 by Harold Black
I have a user form where the user needs to select a sketch segment. Once selected, you click on accept and some calculations are performed. I'm having the hardest time figuring out the correct way to code this. Below is my first attempt taking some bits of code from a different example I found online.
    Dim swApp                       As SldWorks.SldWorks
    Dim swModel                     As SldWorks.ModelDoc2
    Dim swModelDocExt               As SldWorks.ModelDocExtension
    Dim swSelMgr                    As SldWorks.SelectionMgr
    Dim swSketch                    As SldWorks.Sketch
    Dim seg_selection               As SldWorks.SketchSegment
    'Make classes to listen for events
    Dim WithEvents swDraw As SldWorks.DrawingDoc
    Dim WithEvents swPart As SldWorks.PartDoc
    Dim WithEvents swAssm As SldWorks.AssemblyDoc
Sub UserForm1_Initialize()
    Set swModel = swApp.ActiveDoc
    Set swSketchMgr = swModel.SketchManager
    Set swSketch = swModel.SketchManager.ActiveSketch
    swModel.SetAddToDB True
    If Not swModel Is nothng Then
        Select Case swModel.GetType
            Case swDocumentTypes_e.swDocPART
                Set swPart = swModel
            Case swDocumentTypes_e.swDocASSEMBLY
                Set swAssm = swModel
            Case swDocumentTypes_e.swDocDRAWING
                Set swDraw = swModel
        End Select
    Else
        MsgBox "Please open the document"
Sub HandleSelection()
     While swSelMgr.GetSelectedObjectCount < 1
          DoEvents
     Wend
     Set seg_selection = swSelMgr.GetSelectedObject6(-1)
Sub SomeCalcs( swSelSpline as SldWorks.SketchSegment)
     boolstatus=GetSplineEndPoints(swSelSpline)
     'rest of code in here is for calculations
Function GetSplineEndPoints(segment as SldWorks.SketchSegment) as Boolean
     dim swCurve                                             as SldWorks.Curve
     set swCurve = segment.GetCurve
End Function
I get an error saying
Object variable or With block variable not set, pointing to this line set swCurve = segment.GetCurve
I defined swCurve and segment is defined in the Function. Some how my code is not seeing my selection.
